Center Bolt Valve Cover Gasket Problem
Lone-Shark
Posted: 10/15/12 06:35 PM
Hey guys, I just bought some new aftermarket valve covers for my aftermarket aluminum heads, they're the tall, finned, aluminum valve covers, but I've ran into a big problem, I can't find any valve cover gaskets for them, all of the valve cover gaskets that I've found are too small/short, does anyone no any Fel-Pro or Mr. Gasket part numbers that will work? Surely someone would make valve covers that aren't going to have the proper gaskets available for them, right? Below is a link of the valve covers I purchased.
http://www.ebay.com/itm/SBC-CHEVY-TALL-ALUMINUM-VALVE-COVERS-CENTER-BOLT-FINNED-WPM-VC-501-6-/200765495507?hash=item2ebe8e58d3&item=200765495507&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Posted: 10/15/12 09:17 PM
Lone Shark
you need valve cover gaskets for 1987-1996 Vortec Heads
Jegs P/N 375-1648
Lone-Shark
Posted: 10/16/12 06:15 AM
So those don't have to be stretched or anything?
Posted: 10/16/12 06:44 AM
buy the gaskets for the model/year of heads you have...end of problem
Posted: 10/16/12 01:12 PM
Lone Shark
  You should not have to stretch them.  You need to know that they are for a Vortec style head and valve cover
Lone-Shark
Posted: 10/17/12 09:37 AM
@ Scott - I've looked at every gasket offered for Vortec and non-Vortec style heads, and all of them are still too small.
@ Pepsi - It looks like they're all still the same.
Posted: 10/17/12 09:51 AM
how small? 1/8" 1/2" picture would explain a lot
Lone-Shark
Posted: 10/17/12 10:36 AM
Probably closer to 1/2", I'd post a picture, but I've already taken back the other gaskets.
Posted: 10/17/12 12:03 PM
do the gasket fit the heads but not the valve covers?
Posted: 10/17/12 12:27 PM
So how do they(VC) look sitting on the head? without Gaskets, does the top of the head fit in the gasket area? I have had to stretch lots of them but not a 1/2 inch and that is mostly cork if they are the rubber type maybe soak them in hot water?
Posted: 10/17/12 12:32 PM
did they offer gaskets when you bought them?
Posted: 10/17/12 03:56 PM
Good idea 'Lark. Ask the place you bought them what gasket they suggest using.
Posted: 10/17/12 11:52 PM
i bought some aftermarket, aluminum valvecovers, for centerbolt heads a few years ago.  i used some orange rubber gaskets that had to be slightly stretched.   it was no big deal.   i put some rtv silicone on the valvecovers, stretched the gasket into place, and used a few clothes pins to hold them in place.
   do your valvecovers have the inner rib, on both ends, that you can stretch the gasket around?
Posted: 10/18/12 04:29 PM
Geez Lone Shark. I don't know what to say.I order kits and never have a problem. I'mConfused
74t56nova
Posted: 10/22/12 04:12 PM
just had this problem this summer....try Fel Pro VS 50088 R...   these need to be stretched!!!...i thought they were way too small when i got them but i stretched them by hand (like a rubber band),dont over do it!! put a little rtv black on the valve cover surface to keep them in place,  let it dry 15 min, then put them on...no problems or leaks...
