drag time
vega4
Posted: 09/28/12 01:43 PM
My Grandprix just ran a 14.09 at a 106.4mph. It has a 383(chev) with Edelbrock heads, stage three Summit intake, and a single pattern can with 509lift, 108 lsa and 246 degrees of duration at fifty thou lift.  It has a th350 with a 3000 stall converter and 4.11 gears.  And just so you guys know twenty year old snow tires have terrible traction
Posted: 09/28/12 02:36 PM
I need to see a time slip to make a proper determination
Posted: 09/28/12 03:57 PM
Vega4.
What is there a confrontation between 2 cams, and other information. Try to break it down a little better. It actually should have run better.
Give us a little more information, a little less confusing. Confused
Posted: 09/28/12 09:45 PM
Vega4:
It really doesn't help anyone when you make multiple posts on several forums.
Thanks.
vega4
Posted: 09/29/12 12:59 PM
I can't figure out why it keeps adding that last part.  I tried post at carcraft but it was doing it here too
jpatt87
Posted: 09/30/12 02:04 AM
im no expert but when my car ran around 106 in the quarter i was doing around 13.00, your vega is light and should run faster then that, these guys will help ya figure it out.
Posted: 09/30/12 08:14 PM
Yes I agree you are at least a second slow for your MPH.
Tires should be your first move to much quicker ETs. I would venture a guess that you are between 325 and 350 hp judging by your speed and estimating your weight at 3200-3300 lbs.
vega4
Posted: 10/01/12 04:21 PM
I planning on getting some.  But the drag strip's closed for the winter, so I'm not in a big rush.  The weight was closer to 3800 or 3900 with two fat guys, so I was pretty happy
jpatt87
Posted: 10/01/12 05:36 PM
what was your 60ft time
Posted: 10/01/12 06:43 PM
If the weight was that high I would push my guess up to 420-450hp.
Get those tires and reduce the weight and you will be seeing some low 12 second times.
Posted: 10/02/12 06:49 AM
And only One Fat Guy at a Time!.Have Fun with your Toy.
Posted: 10/03/12 06:36 AM
Icon Quote76Skylark:
Grin  Grin
vega4
Posted: 10/03/12 04:57 PM
Icon Quotejpatt87:
It was 2.55 secs.  the other fat guy was a hitch hiker, he said he was in a rush!
Posted: 10/04/12 08:09 PM
I think my tow truck had a better 60' and yes I did run my tow truck down the track once. If I remember right it ran 11.9 in the 1/8th. It was quicker than a lot of rice cars which ran in the 12 and 13 second range. This was with a 350 motor in a Chevy 3500, 3 ton dually. The 2500 with the LS motor was quicker but I never took it to the track.
Getting some decent traction will dramatically reduce your times but it will not change your mph much.
vega4
Posted: 10/05/12 05:52 AM
They don't call it a drag'in wagon for nothing.
