4 wheel disk brakes on a 79 camaro
brakeless
Posted: 04/21/12 12:09 PM
im trying to put disk brake rearend under my camaro the rearend came out of a 79 trans am i got the porportion valve and master cyl. what i need to know is how do you tell if the porportion valve is for disk/disk and not disk/drum someone else took the valve off for me please help
Posted: 04/21/12 02:30 PM
Icon Quotebrakeless:
I would compare both numbers on the valves....
The master cylinder is larger to hold more brake fluid and the valving is internally different... Grin  Cool
Make sure to bleed all the air from the system..
Make sure the master cylinder rod is connected to the same hole in the brake pedal.
