350 Block casting number 14093638
Rich9164809
Posted: 09/23/11 05:23 PM
Hello to all,
I purchased a block to use in my 80 Corvette. Not knowing this block designed to be used with a roller cam or a standard camshaft depending when what year the block was manufactured I am lost with the following problem. After looking at this block it was built for a standard camshaft not a roller. The 2 holes are present but not tapped in the front of the engine where the camshaft thrust plate would mount to prevent the roller camshaft from " walking " forward. My question if anybody can help me - I Installed a roller camshaft for a non roller block - the back of the timing gear of the camshaft rubs the block where the " thrust plate " would mount too if it was built with a roller camshaft. If this block could be used with either camshaft ( you would have to tap the 2 holes for the thrust plate for a roller camshaft ) why does the camshaft gear rub ? Does it take a special camshaft gear ? What am I missing - thank you for help in advance...
Posted: 09/23/11 07:24 PM
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
to start out with the info....
Rich9164809
Posted: 09/24/11 09:50 AM
Was the face of the flat tappet camshaft designed different when used in this block? Did they use a different camshaft gear with the flat tappet camshaft when it was supplied with this block ? By this I mean is the gear designed diiferent from a 350 camshaft gear supplied with 69 Camaro ?
Posted: 09/24/11 10:43 AM
What style of timing set are you using?
Rich9164809
Posted: 09/24/11 05:32 PM
Edelbrock 7800 gear / chain set double roller chain - thank you for your help
chevelle83
Posted: 09/25/11 02:04 PM
the factory roller cams use the thrust plate, that keeps the cam from walking in the block.
some of the aftermarket roller cams use a thrust button or cam button, in place of the thrust plate.
Rich9164809
Posted: 09/29/11 04:42 PM
Spoke to the guys at GM Hi Performace today. They said eventhough the block designed to accept a flat tappet camshaft or a roller camshaft the block was not designed to accept a roller camshaft or a flat tappet designed for the bloacks manufactured before 1987. So now I'm looking to purchase a 350 block - 4 bolt main - standard bore - pre 87.  Thanks for the help to all .
