123 Last
GM Goodwrench 350 build
tchavers92
Posted: 09/26/11 12:38 PM
I am buying a used 4 bolt main gm goodwrench 350. I need some guidance on rebuilding it. I need to know if the bottom end of the motor and heads could support a bigger cam intake and a carb. I think it is a tbi engine with the swirl port heads. I am going to go through it and replace the gaskets and check the bearings and replace if needed. What else should I do? what would be a good cam for this motor? intake and carb? I may be buying the newer style vortec heads for it.
Any suggestions?
chevelle83
Posted: 09/26/11 07:31 PM
a stock mild engine is great for a stock daily driver,,,,,,,,,,,,,
what duty is the engine gonna be up to?  car? truck? race?
its best to build the engine for the intended use.
Posted: 09/26/11 07:49 PM
Vortec heads in stock trim will only support .460" lift,,, max.
Posted: 09/27/11 12:38 PM
more info. Wink
tchavers92
Posted: 09/27/11 12:45 PM
Im just wanting wanting to build a good strong motor that can be driven daily without making me go bankrupt. I guess a street/strip motor?
tchavers92
Posted: 09/27/11 12:51 PM
Sorry. Didnt mean to post that so many times. It said there was an error
Posted: 09/27/11 12:55 PM
if your gonna tear it down, get new cam bearings & freeze plugs.    one way to build your engine is around your cam.   that will determine the compression you should shoot for, & the heads, carb, & intake, etc.     the more info you can give these guys, the better.     i see street/strip.    what kinda car is it?   auto/manual?   rear gear?  are you willing to swap gears if need be?   willing to buy an aftermarket stall converter?   how much street use?    this will aid in picking out a cam.
tchavers92
Posted: 09/27/11 01:06 PM
I am going to tear it down so should I get a master rebuild kit? It is automatic has the old 700r4 in it. I am considering a stall converter and i want to put 3.73 gears in the rearend. I dont want nothing real radical just a reliable truck that can get up and go when i want it to.
Posted: 09/27/11 01:57 PM
Icon Quotetchavers92:
No biggie I removed the extras.
Next time just give it some time and the post will appear.
tchavers92
Posted: 10/02/11 10:35 PM
Any more advice?
chevelle83
Posted: 10/02/11 10:52 PM
350 block,,,,,
master engine kit is fine, just specify,,
flat top pistons
460-488 cam
summit 2.02 heads
headders
650 cfm carb
performer rpm or similar intake
roller rockers
3.73 gears are great with a 700r in a truck
drive 100K miles and enjoy.
tchavers92
Posted: 10/02/11 11:14 PM
looks like some good mild performance parts. just about what i was thinking. Thanks for the help
tchavers92
Posted: 10/03/11 06:56 AM
what do you mean by a 460-488?exhaust lift? Also the heads what is the 2.02 referring too? would a comp magnum 260hr cam be good for a daily driver?
chevelle83
Posted: 10/03/11 09:11 AM
uh,, that is a 4.3 v6 cam.
I am referring to the gross valve lift, in other words dont go huge with the cam  simply cause it will kill bottom end torque (under 2000 rpm )
look at summits site and check out their name brand cast iron heads, I love em they cost $750 out the door ready to bolt on.
tchavers92
Posted: 10/03/11 09:56 AM
yeah i typed that in wrong. are the summit heads better than the gm performance vortec heads?
123 Last
