rocker arm torque spec?
camaro10lvr
Posted: 05/20/11 10:51 AM
I have a 350 small block, 4 bolt main with 2 piece rear main seal. I have some 305 vortec heads on it, what is the torque specs/torqueing procedure  for the rocker arms? should there be about the same amount of thread showing on each rocker stud after theyre torqued? thanks
1979 Chevy c1500 stepside -350 engine in progress, th400 soon to come.
2006 Mitsubishi Eclipse GT - 3.8L MIVEC SOHC
Posted: 05/20/11 10:56 AM
http://forums.chevyhiperformance.com/70/8751516/general-chevy-discussion/roller-rocker-sounds/index.html
Read this!!
You don't torque rocker arms, you set the valve lash(solid lifters) or lifter preload(hydraulic lifters).
Posted: 05/20/11 01:15 PM
Read the thread "roller rocker sounds" for lashing valves properly.
camaro10lvr
Posted: 05/20/11 02:04 PM
yeah i tried following the instructions in the haynes manual and some of the rockers were still loose after so i guess ill do it one by one then.
Posted: 05/20/11 08:40 PM
Did you go to that thread?
Watch the vid on setting valves?
