123 Last
el camino
1980elcamino
Posted: 05/06/11 06:31 AM
Im going to use this thread to show you guys the projects I do on my el camino. Its a 80 with a 350/350 combo and 3.73 gears. Ill start with what I did yesterday.
Heater delete- I removed my heater because although it is a street car I have only driven in the rain once and never when it is below 60 degrees. The little flaps inside didnt seal, and blew black powder every time they moved. So, because it was easy to do and it would make things look better I removed it. It was easy getting the actual heater out. Just remove the trim and screen thing on top, all bolts and wires and pop. It was amazing how much better I could wire my dash. It took up so much room inside you could fit a nitrous bottle. Seriously, if someone does that it will fit, I was thinking a little fake vent to turn the knob. Smile Anyways then I had a huge hole in my fire wall. I went in town to a local welding store. They had some scrap aluminal sheet metal laying around they sold me for $15. Way cheaper than the panel on ebay. After alot of time with cardboard, and sheers this is what I had.
002 1
001 1
It really changes the engine compartment. I will brobably paint it black bu tin the sun it looks good now because I did a swirl pattern with sand paper. We will see. Next project: new fuel pump and rear roll pan mounting.
Posted: 05/06/11 07:50 AM
Not bad so far keep us posted.
Posted: 05/06/11 09:58 AM
definetly makes it easier to work on things.    id paint it black and use some black rtv to seal any leaks.     kinda makes me appreciate a nice full stainless firewall on a show car.   theyre not that easy to make clean.    lots of test fitting with cardboard first.     you can probably scrap that brass heater core for what the aluminum costs. Laugh
Posted: 05/06/11 10:30 AM
Now you have a good spot to mount an MSD box and a droF starter relay.
1985olds
Posted: 05/06/11 02:29 PM
i really like those m/t valve covers
1980elcamino
Posted: 05/06/11 02:30 PM
That would look good. I was thinking baout mounting the fuel pressure reg. too. Why would I want a ignition box. I see alot of people running them. Would I have top get rid of my hei distributer?
Here is some pics of todays projects.
Elcmaino002
Elcmaino007
Elcmaino008
This was a really easy project. Took about 40 min. Mounted nice. The sides dont quite flow berfect with th ebody but they are really close.
Next project - my choo choo front end.Elcmaino006
Hopefully this will be as easy as the back.
1985olds
Posted: 05/06/11 02:33 PM
you can keep your hei, just make sure you use the magnet triggfer harness to disable the ignition module or it wont idle less than 1500 rpm. if you choose to do it, that was my mistake when i put mine in
1980elcamino
Posted: 05/06/11 02:41 PM
I was wondering why my engine pics looked so bad and my car ones looked good. My phone was on green tint. Ill have to get some new pics up.
Posted: 05/06/11 03:05 PM
you have one clean and mean lookin ride there 1980.   Cool
Posted: 05/06/11 03:23 PM
looks pretty good.
Reminds me of the 1983 elcamino I had.
Posted: 05/07/11 08:03 AM
Sharp truck!  Cool  What is that rotten part in the pic? Bumper reinforcement?
1980elcamino
Posted: 05/08/11 04:14 PM
The back of the old bumper. Half of the bumper was chrome tape. Actualy worked prety well.Elcamino001
Posted: 05/08/11 06:58 PM
Nice!
1980elcamino
Posted: 05/13/11 04:20 PM
So I ran into some problems with my car today. After the head swap I seem to ahve all gaskets sealed except one. Problem is I dont know which one. It is dripping down the pass. side of the engine and falls on the header. Not good. Any ideas of where it could be coming from? I used silicone under the manifold, dont know if it maters.Also has anyone ever built their own rear control arms? lower in particular?
Posted: 05/13/11 04:56 PM
maybe just a valvecover gasket leak?     ive been wanting to box my lower trailing arms for awhile.    maybe ill do it soon.   i did my track bar already.   ill get ya a pic tommorow if i remember.
123 Last
