1978 nova rear end
Posted: 02/13/11 05:28 PM
Just got a 1978 nova all original need to know the gears that came in it in the rear..? Thanks Grin
Posted: 02/13/11 05:51 PM
depends on the factory engine trans combo.    4.11 all the way up to a 3.08  10 bolt or 12 bolt??
Posted: 02/13/11 06:11 PM
There should be a code stamped onto an axle tube, probably covered in dirt but if you can find it I should have a book to decode it.
Posted: 07/20/12 06:22 PM
The axle identification code is the 3rd letter of the axle code located on the front of the right-hand axle tube, about three inches from the differential cover.  3.08 10-bolt was the most common, but can't be sure without the code.
