Painting my car for the first time.. Any tips?
90formula
Posted: 02/08/11 11:11 PM
I just bought a 90 formula and im planning on sanding the car and priming it black. Im using a small compressor to paint it, will that work? I have two that I will be switching off with.
Posted: 02/09/11 07:53 AM
You may have to go one panel at a time. It takes about a 5 HP with a 60 gallon tank, to keep up with a spray gun and keep a wet edge going around the whole car.
chevelle83
Posted: 02/09/11 03:37 PM
you need at least 10 cfm and 12 cfm is better.  look on the compressor and it will have a tag that tells the ???cfm@???psi
My 60 gallon is 13.5 cfm @ 40 psi and 10.5 @ 90 Psi
jpatt87
Posted: 02/12/11 03:37 PM
depends on what kind of gun you have. SOme hvlp guns do noy use low pressure, the first car i ever painted was with a nail gun compressor that you can pack around, it took forever but it worked.
joshtimber
Posted: 10/29/12 11:03 AM
BTW, how much these guns cost and how to choose the best?
Chevy Spark 2011
Posted: 10/29/12 04:03 PM
Spray guns range from $15 to $1,000. The expensive ones are best.
