123 Last
71' monte carlo
garrettfisk
Posted: 12/04/10 12:52 AM
i built a 383 and i was wondering my self what the power would be on it, i used performer rpm heads 70cc. a summit 1107 cam, specs are 488 510 lift 234 244 dur. eagle balanced bottom end with -12cc pistons. performer intake and a jet stage two q-jet.full tube headers roller tip rockers. now i think it is over 400 hp because my dad has a 70 vette with a 396 with a bigger cam and better exhaust so its more then 425 hp and my boat is just as fast as his. could some one help out on this issue
Posted: 12/04/10 05:27 AM
try camquest.com.  they will give you an approx h.p. rating.
Posted: 12/04/10 07:11 AM
That old grind of a cam is hurting power.
With what you have I would guess about 390HP
Posted: 12/06/10 08:45 PM
+1...Those are the same specs as the Eddy RPM cam...sounds good but leaves much power on the table...EX-perience with it in nearly indentical motor but on dry land Smile
Pman, if I may, look at the lunati Voodoo cams for better power numbers...find a free simulator and play with the numbers until you find something that will really put some smoke on the water Smile
Skylark
Posted: 12/07/10 05:52 AM
GreatScott,IDJ me thinks Frank Zappa is fishing for MudSharks.that must have been a hell of a party 'cause they burned that Floating Hotel down.What you say? It's only RockandRoll.
garrettfisk
Posted: 02/14/11 07:47 PM
ok so sence i put this post up ive been lookin for difffernt cams and readin about cams. it seems by the numbers im readin i cant find a cam with lift equil or bigger with any differnt duration. if you could help please say somthing
Posted: 02/14/11 08:01 PM
Icon Quotegarrettfisk:
Several folks have already pointed you in the right direction,,,LUNATI,,, VOODOO
There is more to cam selection than just numbers.
Forget EDDy's lame duck cams,,,
Grin
Posted: 02/15/11 07:03 AM
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam Kit
Part Number: 60103LK
Jobber Price: $198.34
Posted: 02/15/11 10:46 AM
Yep,,, can't make it much plainer than that Pman.
Grin
Posted: 02/15/11 12:15 PM
+1.  Cool
OleSkool731
Posted: 02/22/11 06:31 AM
i enjoy reading all these to see what i can learn. i find it very interesting
garrettfisk
Posted: 02/28/11 02:11 AM
doy uo guys know any thing about crower cams. all i really hear about is comp or voodoo. because most of the cams from those two are on 110 centers. at crower there down to 106 centers and 108. i was readin that the tight they are the lower your power curve is in the rpm range. and help would be nice. thanks
OleSkool731
Posted: 02/28/11 07:24 AM
have you tried crane cams yet? i get to hear a lot of good thing about them from quite a few guys we go to church with.
garrettfisk
Posted: 07/29/11 09:06 PM
alright now im putting a 200 4 r tranny in it and i was wondering what else i need to install the tranny. its commin with a 2500 rpm stall. i ordered it from shift my gears. any help would be great
OleSkool731
Posted: 02/26/12 10:52 PM
For the stall, see what the cam calls for, it should be able to help the red light idle.
123 Last
