need more horse power help
corey2481
Posted: 08/11/10 01:22 PM
Hey group I'm new but i just finished rebuilding my motor and my transmission on my 77 chevy malibu. the motor, I put in a bigger cam 454 lift, dual chain timing chain, lifters, intake manifold rps, holly 650 double pump carburator, 1 1/2in spacer, headers, down fire exhaust, cherry bomb turbo mufflers, transmission is a 350 short tail, hurst shift kit, and stall convertor... any suggestion on how to get my horse power increase more?? And if anyone knows where i can a bigger gear rearend, pleae let me know.
gettnlarge01
Posted: 08/11/10 04:02 PM
changing mufflers will help alot
Posted: 12/08/10 11:58 AM
+1 and tuning it in will help also.
Posted: 12/08/10 04:40 PM
If you have decent pistons in it you can hook up some Nitrous and get a 100-200 hp boost without too much trouble. If you have the stock cast pistons I would keep it down to about 75. If you don't want to go that route a good set of heads would help a lot.
WRIGHTRACING
Posted: 12/09/10 07:37 AM
Nitrous is our friendLaugh
WRIGHTRACING
www.outlawracing.com
www.dragraceplace.com
www.ndrra.com
3836bbl
Posted: 12/09/10 02:45 PM
Better cam like a solid or roller, More valve lift, springs, larger lighter valves etc, higher ratio rockers, better headers & exhaust, Head porting, more carb CFM, More compression, lighter components, Blower or N2O & more money.   3836bbl/Budnicks
"Fill Your Library Before Your Fill Your Garage"  3836bbl alias Budnicks
Posted: 12/09/10 03:00 PM
supercharge it !
Posted: 12/09/10 03:23 PM
+1 Bud and Joe,,,
money is needed to balance any build.
Skill rounding up power never hurts either.
