Fuel Delivery Problems ?
shortbed85
Posted: 07/19/10 09:58 PM
My 85 chevy shortbed started cutting out when I would go up hills at about 30mph or so, so I replaced the fuel filter. Then it wouldn't start so I disconnected the fuel line outside the filter and cranked it over. No gas . So I replaced the pump.
Hooked it up , tried starting  it  but no gas at the carb again, no gas smell either.So I unhooked the line outside the filter and cranked and got gas alright..
I checked the filter , looked okay but dry as a bone inside that area for the filter in the carb. I have the paper type filter with the small black plastic seal ? spring ? at the end facing the fuel line as I was told that end seals against the ouside nut and the spring inside sits against the closed end of the filter.       Anybody have any ideas or suggestions? going crazy !
I would really appreciate the help Thanks
Posted: 07/20/10 04:39 AM
That plastic deal with the spring is called a backflow preventer. Keeps fuel in the carb rather than letting it drain back into the fuel line upon shutdown. You have it installed right. A thorough check of the fuel line for old leaky or stiff pieces of hose is in order. Rubber lines can rot on the inside and plug themselves, or even suck shut during heavy pump suction. Could be a carb float or needle valve problem, too. Last ideas are in the gas tank. A deteriorated filter sock could be intermittently clogging things up, as could the bottom half of an old locking gas cap that someone had to break off. Seen that before but it didn't cause problems.
Food for thought, thats all!
Posted: 07/20/10 05:56 AM
That plastic deal with the spring called a backflow preventer could be sticking.
Remove filter and blow through the inlet of the filter and see if it allows air to pass through it.
Posted: 07/20/10 01:44 PM
+1
Posted: 07/20/10 01:49 PM
+2
Get a new filter, that should cure the problem for you.
Posted: 07/20/10 05:18 PM
Yep.
69nova355.
Posted: 07/20/10 06:56 PM
yup not that much money.
shortbed85
Posted: 07/21/10 03:45 PM
Thanks for the suggestions , and I will re-inspect my gas lines maybe pump more gas through the lines before the filter..
shortbed85
Posted: 07/21/10 09:20 PM
I did replace the filter with another "new " filter and the truck started up. Tried blowing thru the old one and no luck..What are the odds of getting a bad filter from the store. LIVE AND LEARN .... Thanks guys
Posted: 07/21/10 10:31 PM
I hate it when a three dollar part causes a ten dollar headache Mad
Posted: 07/22/10 04:39 AM
+1
Posted: 07/22/10 05:00 AM
+2
69nova355.
Posted: 07/22/10 06:43 AM
At least its fixed.
Posted: 07/22/10 07:40 AM
+1 nova
The odds of getting a bad fuel filter from the store is actually more common then one would think.
Posted: 07/22/10 08:50 AM
+2
EVERYTHING, and I mean everything needs to be looked over and checked,,,
and parts are getting worse instead of better.
Why,,, no more or very little human inspection or quality control.
So now robots get blamed.
