Chevy V8 Vortec Cam numbers.
GM-JOCKEY
Posted: 04/15/10 05:02 PM
Hi Guys, cant find any info anywhere about Vortec Cams, how many different grinds are there (factory ones) and which one do I have. The numbers on the end are; 1264 fm-L 3009-20. Then there are the numbers on the shaft which are; 29499 2214.
Can anyone help to unlock this mystery..??
GM-JOCKEY
Posted: 04/17/10 02:52 PM
Hmm, looking like its not only a mystery to me
GM-JOCKEY
Posted: 04/20/10 12:18 AM
bump
Posted: 04/20/10 07:37 AM
isky sells a cam part# 201264, megacam, dur 264, lift .450 .  could just be a coincidence, but might be worth checking out.  not tyring to steer you wrong, just nobody else responded. hope it helps.
Posted: 04/20/10 08:41 AM
Could be Joe,,,
I'm stumped and never ran across that number
GM-JOCKEY
Posted: 04/21/10 12:08 AM
THANKS for the info Guys, I didnt think that this subject would be a hard one..!!
will follow up on this.
Posted: 04/21/10 04:53 AM
yea, let us know what you find out.
Skylark
Posted: 04/21/10 11:05 AM
"Ol boy tell us xactly what the vehicle was and we may get a better idea they'r were not that many versions year too if you can. then there is always the Dealer
GM-JOCKEY
Posted: 04/22/10 12:30 AM
The story goes, that the cam came out of a 1999 GMC Yukon. (it also has green paint around the shaft alongside the dizzy drive gear.) Dont know if that means anything.
I was told by one dealer, "there are numerous factory Vortec Cam options." so with that in mind I set out to find what sort of grind I have.
Skylark
Posted: 04/22/10 03:33 PM
the green paint is an I.D. as well as numbers.that dealer might not know how to read.
GM-JOCKEY
Posted: 04/24/10 12:49 AM
BUMP
Posted: 04/24/10 06:14 AM
GM,,,
Mic the base circle and then across the lobe,,, subtract the small number from the large number,,,,,, and multiply by 1.5 (your rocker ratio) the number you get will be your valve lift.
With that "hard" number you can start searching for what you really have,,, besides green paint.
Wink
Posted: 04/24/10 07:46 AM
I've never seen anyone positively identify a cam from markings. Blanks marked the same way could easily be different grinds. It has always been a case of measure it like tuff said, and get an idea then live with it, or replace the cam so you know what you have. At least in a flat tappet world, anyway. I recommend the latter, but thats just me.
gettnlarge01
Posted: 04/24/10 03:05 PM
you could always use a degree wheel and spare block to make a "CAM CARD"
Posted: 04/24/10 08:58 PM
Icon Quotegettnlarge01:
That's a lot of effort to put in a "nothing" cam,,,
Find true TDC with a positive piston stop,,,
get a dial indicator on each lifter,,,
log the indicated degrees,,,
do all the math,,,
and find out you have .390" lift
I'm surprised I even typed all this,
get a new cam and lifters,
it's cheaper and better
plus now the cam has ID
Grin
