123 Last
My 400 turbo tranny started slipping today and..
Longhorn396
Posted: 10/21/09 10:06 AM
I was wondering if it is going bad or if i need to rebuild it and put a shift kit in it.?? it goes through first and second ok but I have to shift the shifter into third or it will slip. When i do it manually its ok but when its by itself it slips. I need some websites with nice cheap 400's and or rebuild kits and shift kits.
69nova355.
Posted: 10/21/09 12:55 PM
is it old? you checked fluid im sure.sounds like rebuild is coming soon.
gettnlarge01
Posted: 10/21/09 05:11 PM
Kits are cheap but the main question is can you build it yourself or are you gonna take it to a trans shop?
p2-72chevelle383
Posted: 10/21/09 08:24 PM
i had my th350 built last year for 600
p2-72chevelle383
blacksheep84
Posted: 10/21/09 09:45 PM
shift kits sometimes correct problems. they are sometimes called correction kits , shift improver ext. you can also upgrade the valves for higher pressure ones and that will help promote better shifting and lubrication.
i learned alot from this website , they have an extensive amount of parts. they also offer tip sheets for some transmissions.
http://www.400raptor.com/
Longhorn396
Posted: 10/22/09 10:04 AM
Well the fluid is good. but my dad said maybe the modulator is dirty and or the filter. Its in a 69 Chevy CST20 longhorn 3/4 ton truck. I can so the kit myself and not so sure about the shift kit. Im changing both filter and the modulator this weekend so it might fix it.
gettnlarge01
Posted: 10/22/09 05:48 PM
Dirty fluid or filter will def cause trouble in an automatic
Longhorn396
Posted: 10/23/09 05:16 AM
Its kinda fraking me out cause I dont have 1200 for a new quality built tranny. Or even money for a complete rebuid so I thought I would come on here and ask some possible problems.
gettnlarge01
Posted: 10/24/09 04:48 AM
1200 bucks is way to much for a stock 400 trans. You can buy a good one for less than a grand. It costs bout $350 to get one rebuilt with a convertor where I live. First thing is to change fluid and filter to see if it helps
p2-72chevelle383
Posted: 10/24/09 05:41 AM
350 is a good deal 600 is cheap around here
p2-72chevelle383
gettnlarge01
Posted: 10/25/09 05:08 AM
It helps to have friends in the transmission biz.p2 what part of the country do you live?
p2-72chevelle383
Posted: 10/25/09 05:24 AM
flint,mi.best tranny and rear end guy in the city did my tranny for 600 and rebuilt my 10-bolt with a 3.73 posi for 900(1500).where do you live?
p2-72chevelle383
gettnlarge01
Posted: 10/25/09 05:28 AM
Close to athens,ga. I do my own rearend set-ups but I get trans work done so cheap I've never tackled a rebuild myself. If I ever lose my connections I will have to learn to do that to! lol
p2-72chevelle383
Posted: 10/25/09 06:04 AM
ya you cant beat $350.i wouldnt even care if i broke it if thats all it cost me
p2-72chevelle383
gettnlarge01
Posted: 10/25/09 06:09 AM
Yeah if it only lasted 20,000 miles it would be a deal considering most projects dont see 5,ooo mlies a year
123 Last
