transmission linkage
donz67z
Posted: 08/17/09 12:19 PM
can i use my existing powerglide column shift linkage with a th-350 transmission? i have a 67 impala, thanks
Posted: 08/18/09 08:04 PM
yes.... but you might not get manual low gear with the th350...
the PG shifts like this.
p r n d l
th350s
p r n d 2 L...
what can you do about it...  there might be slightly later detent gates available for the column...  out of a TH 350 equipped car...  perhaps a 68...  perhaps something later like a gm van with key on the dash..    somebody may know this....  but it does require a real tear down of the column...
but like i said.. it will shift...    the neutral safety switch will also be slightly different...    there is a difference in angles between park and reverse between the 2 transmissions...
make sure that until or if you decide to change it later.. that it locks into park...
and that you feel the detent in the trans pass through R N and into ***  so you don't end up driving it in second gear..
