Need numbers help on a 68-327
marksj9653
Posted: 06/27/09 12:05 PM
Can anyone help me out on this motor Number ....Pad number in front of the motor is as follows T0419HH and 18J258073.....then on the back of the block its 3914660 and D 17 8 and T14 and conv 1....I get the april 17 1968,But The HH is throwing me...Says its a car motor,,,but could it be a Vette Motor...and I double checked it is HH ,has camel back heads and only a 2v carb.....was in a pole barn that I just bought...any help would be appreciated ...heads are #3917291.............thanx
Posted: 06/27/09 12:51 PM
The HH suffix code comes up as follows 1968 327 4brl. 250HP 2bolt mains and it was originally in a impala.
chevycountry88
Posted: 09/04/09 04:17 PM
I just bought a 327 and was doing some research to find out more about it. The guy told me it was a '68 and if he remembers right it came out of an Impala. When I googled the T 14 CONV #1. I found your post. I can not find a HH. I did find H2 660 633, (the 33 could be 88) with a T under the 2. Why does his have HH and mine has an H2 and a T under the 2. Also, would you mind telling me what does 4brl mean? I appreciate the help. Thanks
Posted: 09/04/09 04:48 PM
4 BRL stands for 4 barrel carb.
Posted: 09/04/09 04:49 PM
There is no H2 suffix code that I could fined what is the casting numbers on the back of the block.
Was there any other letters on the front pad.
canted
Posted: 09/04/09 05:04 PM
Where are you getting your numbers/letters, country? The info listed above comes from a pad on the block, in front of the right cylinder head. The top line in the stamped numbers/letters on this pad, ends in a suffix code that tells a lot about the engine. The example above ends in two letters but many have three. There are several places on the web to decode the stampings, one I like to use is "nastyz28.com"
Jim
70 El Camino
461 solid, m20,
pics in readers rides
thanks for over 3000 views
chevycountry88
Posted: 09/04/09 06:31 PM
I could not bring the engine home today, but I did take some pics. On the back of block on the ledge on the left side: GM 3914660 with the T14 CONV 1 being the second set going from left to right and the H2 660  633 (33 may be 88) with T under the 2 is on the right hand side on back of the block where the trans would be covering it. I really appreciate you guys helping me out. I'll be going to pick up the engine one day next week and clean it up and see what else I can find, but by the pictures I took I could not see any #'s on the front of the block.
SMOKESHOW
Posted: 09/04/09 09:57 PM
Check out Mortec, NastyZ28.com, and Chevymania.  Post your findings and we can all compare.
Posted: 09/05/09 04:28 AM
It was used from 1968-69 and is a 327.
groyster
Posted: 07/29/12 10:18 PM
hello well i just got a block the same numbers 3914660 t14 conv 1 i was wondering HH thing mine says T0925HC what would the HC mean if u could help me please
Posted: 09/29/12 08:36 PM
Engine Front Pad. T0419HH
T=Tonawanda Plant
04= 4th month April
19= 19th Day of April
HH Engine suffix code
Year Engine  Trans Type  Horse Power  BBLS  Application
1965  327      Manual       365        4     Corvette
1966  327      Automatic    300        4     Corvette
thunder80
Posted: 10/03/12 01:25 PM
#3914660 - 327, used in 1968, 1969. pass,chevelle,camaro,nova,truck
