601 HO Heads on a 350
orange77z28
Posted: 10/29/08 12:47 PM
This will be on a 77 Z28 that I have.  I have a set of 601 heads machined for 1.94 intake valves and retaining the 1.5 exhaust.  They were unshroulded and I cleaned up the castings at the intake and exhaust ports, to smooth out the ports a bit.  The chambers were cc'd at 59 cc's.  I have Stock dished pistons, stock bore and stroke and un-touched bottom end in a "010" 2-bolt block with 40,000 miles.  I have a Isky 264/271 Mega hyd./flat tappet cam w/ a 112 lca. The turbo 350 trans. and converter are stock.  Rearend ratio is 342.1.  Now it has a Edel. eps intake, 1 5/8" headers, 2 1/2" exhaust w/ x-pipe. The longblock for now is stock w/ 882 heads and cam (could be a L-48 cam).  How would you think those heads would do with the Isky cam I have. Could I get, say 350 hp with all of this.  Going to rebuild a "880" roller block next and some opinions some on that later.  I'm a new member to this site.  Grin
GibTG
Posted: 10/29/08 12:54 PM
You will most likely have upwards of 9.5:1 compression, so listen carefully for pinging and you will probably need to run pump premium.
A true 350 Horsepower at the flywheel may be slightly optimistic, but it's possible.
~Gibs
orange77z28
Posted: 10/29/08 01:01 PM
The block will not be decked when I do this. I'll clean it up and will use a .015 steel shim gasket (felpro #1094).  I was told more like 10.0 to 1.
Posted: 10/29/08 01:16 PM
Well your compression depends on how deep the dish is on the piston.You should have around 350 H.P.
orange77z28
Posted: 10/29/08 05:54 PM
Icon QuotePontiacman2:
Can't seem to remember that at this time(dish volume).
orange77z28
Posted: 11/05/08 10:16 AM
My dish volume is 12cc
Posted: 11/05/08 10:57 AM
You will have 10.03:1CR and I still say you will have around 350HP
GibTG
Posted: 11/06/08 02:25 PM
You will more than 10.0:1 compression.
You better be wary of pinging on pump fuel.
~Gibs
brocluno
Posted: 11/06/09 07:21 PM
That's weird, I just got back from the machine shop after having mine cc'd - they came in at 53 cc.  416 head are about 58 cc, but I don't think Chevy made two series 601 heads?
brocluno
Posted: 11/06/09 07:22 PM
delete double post;  SBC 14022601 heads are 53 cc.
gettnlarge01
Posted: 11/07/09 05:51 AM
The advertised cc's for SBC heads arent correct. I've cc'ed some chambers that were supposed to be 76ccs and actually ended up with 84ccs. They were stock untouched heads.
Posted: 11/07/09 06:13 AM
601's have 53-56CC cHambers.
