Vapor Lock????
tradinpinks
Posted: 10/02/08 05:40 AM
purchased a 55 2 weeks ago and have only driven it a few times. Runs strong, 383 mild build w/ electric fan added to stock radiator. Motor shut off a couple times and fired right back up, until I guess it got too hot and vapor locked????
Anyone had experience with this? I researched it, and apparently it was an issue back then.
gm2500hd454
Posted: 03/17/09 10:21 AM
shur was  but the 383 os an ok motor but what the hell something that old needs a big block to haull its body weight but if your into small blocks that ok
Posted: 09/21/09 01:09 PM
Vapor lock usually occurs when the motor is shut off for a short period of time and then restarted. The motor and fuel lines have time to heat soak and boil the fuel out of the carb/fuel lines. I doubt what you had was vapor lock, more likely some other kind of fuel starvation or ignition problem.
canted
Posted: 09/21/09 02:41 PM
^ what he said.
Jim
70 El Camino
461 solid, m20,
pics in readers rides
thanks for over 3000 views
