267 engine build
rdm267
Posted: 09/03/03 10:28 PM
1980 sb 267ci ,rebuilt 305 heads,new erson ev100 cam,lifters &pushrods,headers,older elderblock performer dual plain intake. holley 4160 single pumper. I didn't degree the cam!engine starts good!sounds strong ! put it in drive & excelerate it has no power! push down on the pedal and nothing !will someone tell me whats wrong with this damm engine?
V8Astro
Posted: 09/04/03 11:30 AM
When you say you press the pedal, and "nothing," do you mean just no power? If so, it sounds like your timing is off (maybe too far retarded). Generally the more advanced the timing, you get a little more torque, but a lot harder to start. I don't want to insult your intelligence, but did you put a timing light on it? Are the valves adjusted right?
1990 Chevy Astro "Family Holler"
1973 350 V8 with TBI - soon to be Edelbrock MPFI
Hedman headers, high-flow cat, dual 3-inch exhaust
TransGo shift kit
1999 Chevy Astro - Family's "normal" transportation
http://v8astro.homestead.com
Tacoma, WA
Diney355
Posted: 12/02/12 06:05 PM
Your compression is too low because you have 305 heads.
Put back original heads.
You only need a cam with .420 lift max on this engine.
put 3.08's in the rear.
Get a modern catalytic converter.
And off you go!
Could be you over carbed it too.
These work best with quadrajets.
Posted: 12/02/12 11:27 PM
WOW
another single posting OP gets a reply after NINE years
Posted: 12/03/12 06:08 AM
Icon Quote68scott385:
WOW
Over the years I have suggested to posters to go back and read some older posts,this poster must Know Dr.Peabody(Waayyy back Machine)
Posted: 12/03/12 10:06 AM
Good advice John, reading what's already here is always better than making the natives rehash the same info.
...must have got some bad directions from Boris & Natasha. Smile
Posted: 12/06/12 04:18 PM
It was Bullwinkle!!!!!!
Posted: 12/06/12 08:21 PM
Icon QuoteDiney355:
And off you go!
FYI: Depending on the 305 heads he has your correct, but there are 305 HO heads that have 56cc's. Grin  Cool
Posted: 12/06/12 08:26 PM
Who brought this post back from the grave?
Posted: 12/06/12 08:32 PM
Nine Years and only one post.
He is probably long gone, driving an import and thinking it is quick, sadly enough.
Posted: 12/07/12 11:17 AM
Icon Quoteskyeking:
Bullwinkle wouldn't mislead Dr. Peabody, not intentionally.  Grin
Posted: 12/07/12 04:22 PM
Hi there Agent Scott!!!
Posted: 12/08/12 09:34 AM
What's up Skye, or should I say down? Smile
