350 MOTOR
Daniel.Drakeford
Posted: 09/18/08 08:34 AM
I HAVE 350 MOTRO BORED OUT 40 OVER NOW IS THE MOTOR A 402 OR A 357 WHAT KIND OF HEADERS WOULD BE THE BEST FOR ME WOULD YOU USE A MANUAL FUEL PUMP OR A HOLLEY CARB Confused  Cool
canted
Posted: 09/19/08 05:48 PM
357 would be close as a .030 over nets 355 inches. Mechanical pumps are usually adequate for a carbureted engine. Usually you get what you pay for with headers. A Holley carb has benefits in some areas. Other brands have benefits as well, depends on what you are looking for.
Jim
70 El Camino
461 solid, m20,
pics in readers rides
thanks for over 3000 views
bryancarz
Posted: 09/20/08 07:18 PM
boreXboreX.7853982XstrokeXnumber of cylinders = displacement in cubic inches.
you would take 4.04X4.04X.7853982X3.5X8
it comes out to approx. 358 cubic inches.
BuzzLOL
Posted: 11/04/11 02:13 PM
.. X 2... +1 Bryan and Canted...
.. If the engine already has a Rochester Q-Jet 4 barrel carb. on it... that is adequate...
.. We usually don't bore engines out to make them slightly bigger, but to clean up the bores like new for new parts being installed in the rebuild and/or performance rebuild...
Posted: 11/04/11 07:40 PM
Q-Jets are a great carb, albeit a bit more complicated to work on than a Holley.
I like my reworked Q-Jets. I think I'll take pics of my mods and rebuild, then start a thread, cuz Im reworking 4 right now.
Smile'
Posted: 11/05/11 06:46 AM
That would be a good idea.
Posted: 11/05/11 03:28 PM
Long tube headers are good, and if you have the room underneath where ground clearence won't be a problem, try to fit an X or H tube connector in between. It does help with torque on the bottom end. Q-jets are good if you know and understand them. If you are going to use it use a good hi-output pump and use a fuel regulator if you have to. Set the pressure @ 6PSI to 7PSI. If not use a holley. Summit has a nice special on P/N 03-0201 Pro-Pack. 750 Holley Intake Manifold all the gaskets for $500.00. Won't hurt to Check it out!
Boley1
Posted: 12/25/11 10:40 AM
I have a 350 engine with a V0315FSC ID number.I'm trying to find out what this engine came out of and what year it is.
