more 402 bbc horsepower
71donkryder
Posted: 05/18/08 07:39 PM
i have a 402 bbc completly stock, i wanting to add a 750 cfm edelbrock perfomer carb, a edelbrock victor junior race intake manifold and a set of heddman pro comp hedders topped off with a msd ignition kit which includes billet distributor,msd 6al ignition box, super conductor spark plug wires,18" coil wire. how much horsepower will i gain from adding these simple add ons.
GibTG
Posted: 05/18/08 08:02 PM
I highly urge you to stay away from a single plane intake manifold for this engine...
Consider the plenum volumes of intake manifolds today, what is the most common displacement for big blocks today? The answer is 460+ cubic inches! That means if the plenum/intake runners are fit for a 450 cubic inch engine, they will be much too large for your tiny 402!
Since you have a very small engine with a stock cam that will be making its power low in the rpm range a single plane is of little to no benefit. A dual plane intake manifold like the Edelbrock Performer RPM or Weiand Stealth would much better suit your engine and would have significant gains over the victor Jr. below 4000 rpm.
~Gibs
wieder
Posted: 05/19/08 02:46 PM
The original Performer would be my pick on a stocker.    WIEDER
71donkryder
Posted: 05/19/08 08:57 PM
if i went with a dual plane edelbrock performer intake and keep the rest the same how much horsepower will i gain.
wieder
Posted: 05/19/08 09:32 PM
With only changing one part from the stock combo,the intake on your engine would be around 10hp and 10-15 torque roughly.You add headers the intake will take in a little more air,then change to higher flowing heads and........can of worm syndrome. Laugh    WIEDER
SS402
Posted: 05/27/08 06:07 AM
I run a 402 in my monte, get a edelbrock performer rpm airgap, hvh street sweeper 4-hole tapered spacer, 5-piece hooker super competition headers, MSD Digital-6, Barry Grant 750 Speed Demon, Comp Cams XE268H, 049 oval-port heads, pocket-porting...406hp @ 5000rpm, 472ftlbs. @ 2500rpm..
The 402 in my Monte is radical, 575hp @ 6000rpm, 571ftlbs @ 4500rpm
George
Justin3
Posted: 05/29/08 12:13 AM
I just put a 402 in a 71 k5, I did a .030 overbore,wieand stealth intake,hyper pistons and chromoly rings,241 large oval port heads pocket ported,hooker long tube headers,770 holley truck avenger carb and a RV2 cam dur. @.050 I.204  E.214, sae dur. I282  E292 and valve lift of I.476  E.503. Any well educated guess on the numbers this will put out are apperitated.
