how much will it handle
bjasper24
Posted: 03/30/08 06:19 PM
I have a 4 bolt 350 bored .060 over with srp 8.5:1 forged aluminum pistons, eagle 5.7" forged 5140 light weight rods, eagle 3.48" steel crank, ARP rod bolts and main studs. and i wanted to know how much HP it can handle.
wieder
Posted: 03/30/08 06:29 PM
Do you have billet splayed caps? 4340 crank? If so,my guess on paper would be around 500hp.Anybody else?   WIEDER
bjasper24
Posted: 03/30/08 07:13 PM
stock main caps and eagle cast steel
GibTG
Posted: 03/30/08 08:42 PM
It more than likely can handle a little bit more than 500 horsepower but please realize that it's very difficult for us to determine...
As horsepower goes up tolerances need to go down, and eventually need to be eliminated. The more power you make the tougher it is for ALL the components to handle. We aren't building your engine so if one bearing is a little too tight and you think that the rods, pistons, and crank are STRONG enough to handle 575 horsepower but that much power at that kind of speed spins a bearing then we couldn't have predicted that for you...
It's also worth mentioning that dyno-proven horsepower is a lot different than estimated horsepower. Especially if you're a backyard builder and aren't going to dyno these engines and aren't going to push their limits in competition it's more likely that your buttom-end will be safe since there's a very good chance that your actual power may  be a little less.
~Gibs
bjasper24
Posted: 03/30/08 10:06 PM
i have weiand 142 blower that i am putting on top with around 6-8 pounds of boost do u think the set up is strong enough to support that
Posted: 04/01/08 08:39 AM
Easily. As long as you use good bolts for the mains and rods. If you wanted to throw more boost at the motor, or just for extar insurance, I'd install a main girdle for some extra strength.
bjasper24
Posted: 04/02/08 07:31 PM
will it handle an additional 50-75 shot of nitrous
