327 -corvette motor
327 -corvette motor
Fredsvette65 Fredsvette65
I love my Chevy Chevette! | Posts: 1 | Joined: 09/13
Posted: 09/04/13
02:06 PM
Just got my 65 corvette. It has a 327- 300hp
I like to increase the hp
I like the rumble it has!! If I increase the hp will that
intense and increase the rumble?
Also does aluminum heads increase power
Thanks and hope to hear back
waynep712222 waynep712222
Posted: 09/10/13
05:39 PM
Fred there are so many Ways to modify sbcs in good and bad ways
In order for someone to even attempt an answer with as little if as you have posted would be wrong.
Posted: 09/10/13
05:39 PM
pepsi1 pepsi1
Posted: 09/13/13
07:42 PM
Fredsvette65
If your engine as a lot of miles on it, the best thing to do is a compression test, then a leak down test.
  Small Block Chevys respond to just about any induction modification you do to it. If yours is a 4 speed you will want to know what rear gear ratio you have.
  A few years back I did what I a will call a mild tune up on his 64 Vette.
The engine was coming out to be rebuilt.
  Here is all I did.
1.Back then I chose a Weiand street intake manifold.
2.I did a set of double hump (#186) casting heads. the
heads were ported 2" down into the intake and exhaust runner.
The heads were then Bowl Blended we installed Ferrara 2.01"
intake vales, and 1.64" exhaust valves.
3.We did a 4 angle valve job.
4.The Cam we used was the Crane Factory
350 Horse power/327 cam. Degreed the cam, and we used a Cloyes
Double roller timing Chain.
5.Used a set of Crane roller rockers.
6.We installed a 6AL MSD ignition Box, and a MSD Vacuum advance
HEI distributor.
7.The topping was a Holley vacuum secondary 750 CFM Carb.
8 We ended up with a compression of 10:1:1 it will ping
if we go to far on timing. Even at 36* total advance it will
snap your neck. Grin  Crazy
Good Luck
