1995 350 lt1 roller or no?
swaluda swaluda
I love my Chevy Chevette! | Posts: 4 | Joined: 03/13
Posted: 06/08/13
08:51 AM
Is this a roller cam engine or no, it has a 4l60e trans, Thanks  Stan
68scott385 68scott385
Posted: 06/09/13
08:27 AM
Quite possibly but without numbers it's hard to say. If you have access to it the easiest way to tell for sure is to pull a valve cover and stick a bore light (flashlight on a toothpick-like stem, about 3/32 in diameter, $9ish @ Habor Freight) down the pushrod or oil return hole and see if it has the retention spider and dog-bone guides in place.
Posted: 06/09/13
08:31 AM
The 4L60 got its E (electronicly controlled) in 1994. Prior to that they were controlled similarly to the th350 transmissions.
If you find yourself in need or 700r4/4L60/4L60e tech, let it be known and I'll post some links to some seriously valuable information.
Posted: 06/09/13
08:34 AM
This is an Olds motor but it shows the spider and dogbone guides that are very similar to what Chevrolet uses.
0547 Zps3f60d9f8
redneckjoe69 redneckjoe69
Posted: 06/10/13
07:13 AM
i think all the lt1-lt4's of those years were roller cams.     but, ive been wrong before, lol.
pepsi1 pepsi1
Posted: 06/10/13
08:27 PM
Grab some numbers from the engine. Maybe we can find it that way. I had alot of the LT1's apart when I worked for a Chevy dealer. They were not all Roller Cam engines. Pull a valve cover off and look inside!
