Item Posts
Sort Order
Interchangeable GM rearend parts. I have a 77-cadillac seville posi
hardroller
Posted: 02/23/13 04:36 PM
I have a 1977 cady seville posi rearend which is a leaf spring hung rearend. It looks simular to a oldsmobile rear. What i need to know is can i find a CHEVY rearend houseing that i can just change all the guts into from the caddy rear.A GM trailing arm rear that will fit under my 1967-CHEVELLE. It will save me about $2000.00 if i can do this. Need some pros on this problem.
Posted: 02/23/13 07:26 PM
does it have 28 spline axles and a 10 bolt cover?
GM 8.5" Rear - 28 Spline 10 bolt cover with 8.5" ring gear. Ring gear has 10 bolts and pinion has 30 spline. C/clip rear could have 28 or 30 spline axles. Sometimes referred to as the "GM 10-bolt". • Ring Gear Diameter: 8.500 • Cover Bolts: 10 • Ring Gear Bolts: 10 • Spline Count: 28 • Dropout: False • Pinion Support: False • Carrier Breaks: 2.56 / 2.73 • Rear Suspension: Solid • Pinion Nut Size: 1-1/4
Compatible with Models:
Apollo: 1973 - 1975 (Rear) Bel Air: 1970 - 1975 (Rear) Blazer: 1979 - 1994 (Rear) Bonneville: 1970 - 1986 (Rear) C10 1/2 Ton (2WD): 1979 - 1987 (Rear) C15/ C1500 1/2 Ton (2WD): 1979 - 1990 (Rear) C1500 1/2 Ton (2WD): 1988 - 1990 (Rear) Camaro: 1970 - 1981 (Rear) Caprice: 1970 - 1996 (Rear) Catalina: 1970 - 1981 (Rear) Chevelle/ Malibu: 1973 - 1973 (Rear) Cutlas: 1970 - 1977 (Rear) Cutlas: 1985 - 1987 (Rear) El Camino: 1971 - 1976 (Rear) Electra: 1971 - 1989 (Rear) Firebird: 1970 - 1981 (Rear) G10 1/2 Ton: 1979 - 1989 (Rear) G15/ G1500 1/2 Ton: 1979 - 1988 (Rear) G20 3/4 Ton: 1975 - 1989 (Rear) G25/ G2500 3/4 Ton: 1978 - 1988 (Rear) Grand Prix: 1971 - 1987 (Rear) GTO: 1970 - 1977 (Rear) Impala: 1971 - 1988 (Rear) K10/ K1500 1/2 Ton (4WD): 1979 - 1988 (Rear) K15/ K1500 1/2 Ton (4WD): 1979 - 1988 (Rear) K5 Blazer (4WD): 1979 - 1991 (Rear) LeMans: 1971 - 1983 (Rear) Malibu: 1973 - 1983 (Rear) Monte Carlo: 1973 - 1978 (Rear) Nova: 1970 - 1979 (Rear) Omega: 1973 - 1979 (Rear) Phoenix: 1978 - 1979 (Rear) Regal: 1973 - 1987 (Rear) Regal: 1985 - 1987 (Rear) Riviera: 1975 - 1978 (Rear) Skylark: 1970 - 1972 (Rear) Skylark: 1975 - 1979 (Rear) Sonoma: 1994 - 1998 (Rear) Suburban 1/2 Ton: 1979 - 1991 (Rear) Suburban 1/2 Ton: 1979 - 1991 (Rear) Suburban 1/2 Ton: 1979 - 1991 (Rear) Suburban 1/2 Ton: 1979 - 1991 (Rear) Trans Am: 1970 - 1981 (Rear) Ventura: 1976 - 1977 (Rear)
the 67 chevelle rear end is probably an 8.2 will they interchange..
GM 8.2" 10 bolt cover with 8.2" ring gear. Uses 28 spline c/clip axles. • Ring Gear Diameter: 8.200 • Cover Bolts: 10 • Ring Gear Bolts: 10 • Spline Count: 28 • Dropout: False • Pinion Support: False • Carrier Breaks: 2.76 / 3.07 • Rear Suspension: Solid • Pinion Nut Size: 1-1/8
Bel Air: 1964 - 1972 (Rear) Biscayne: 1964 - 1972 (Rear) Camaro: 1967 - 1970 (Rear) Caprice: 1965 - 1971 (Rear) Chevelle/ Malibu: 1964 - 1972 (Rear) Chevy II: 1964 - 1968 (Rear) El Camino: 1964 - 1972 (Rear) Impala: 1964 - 1972 (Rear) Monte Carlo: 1970 - 1972 (Rear) Nomad: 1968 - 1972 (Rear) Nova: 1964 - 1972 (Rear) Skylark: 1964 - 1969 (Rear) Tempest: 1964 - 1970 (Rear) Trans Am: 1969 - 1972 (Rear) Ventura: 1971 - 1971 (Rear) Wildcat: 1964 - 1972 (Rear)
