Item Posts
Sort Order
A Couple of 350 Questions
swaluda
Posted: 03/13/13 04:33 PM
If you have an older 350 block and want to make a roller block out of it, do you need to modify it? Question 2 would be, if you have a roller block, can u make it work if you dont have computer wiring in your vehicle? Question 3 is... If you had a 350 bored 30 over and stuck a 400 crank in it i beleive you would have a 383 motor. now. if you offset grind .025 off the crank, what do you have at that point? Last question is...If you dont intend to drive it too hard, would it be safe to grind the crank? Thanks Stan In NE Pa.
Posted: 03/13/13 04:45 PM
1. no, just buy a retrofit roller cam kit
2. yes, unless you want fuel injection
3. 385 but why not just buy a 3.800 stroke crank & get 388...the 385 can be had w/.040 bore & 3.75 stroke
4. yes but why not just buy a crank of the desired stroke
swaluda
Posted: 03/14/13 02:16 PM
Thanks Scotty for your reply, I guess then that the best thing to do is just get a roller block and rebuild it. If a part in the retrofit package went bad, it might be hard to find a replacement. ( just a thought ) As far as the crank goes, i see your point. I'll be starting a project in May, and i'm trying to get my ducks lined up. So far i have a 350, 400, 454 and a 500 cadilac as a candidate to put in my 50 Plymouth Coupe. Lots of time on my hands, im not in the USA right now, until May. Lots of thoughts and adrenalin flow going on here. Thanks again Stan in NE Pa. (but right now in Honduras)
Posted: 03/14/13 09:59 PM
The retro-fit cam kit includes roller lifters designed to fit older blocks, replacement parts are available from the cam manufacturer.
If you have a 500 Cad waiting for attention...USE IT
http://www.500cid.com/index.htm
http://www.cadillacperformanceparts.com/
Posted: 03/14/13 10:00 PM
http://www.hotrod.com/techarticles/engine/hrdp_0804_541_big_block_cadillac_v8/viewall.html
Posted: 03/14/13 10:01 PM
http://www.crankshaftcoalition.com/wiki/Hopping_up_the_500_Cadillac
http://www.caddy500.com/
Posted: 03/15/13 06:07 AM
swaluda I just want to add my 2 cents worth. As you know by now how expensive Hydraulic Roller Cam set-ups are. Be carefull not to Over Cam your engine.Same rules apply. The Cam Makers are doing so much with Cam Technology today that (Bigger is not always Better). Make sure you use all the selected CAMponents..lol.. the cam maker suggests. Use a ( CLOYES TRUE ROLLER timing chain set-up also). Don't forget to use a Roller Cam Button. Roller cams be-it Hydraulic, Solid, Rollers, tend to walk in the block. It can lead to excessive Cam Gear Wear. Even when using the correct Distributor Gear....Also make sure your rear Cam Plug is not installed TOO-Far inward. I usually install that Cam Plug after I have Mocked the engine up a few times. In fact a Poster had a problem (He couldn't install the oil pump driveshaft). That was actually the caused by the camshaft being pushed too far to the rear of the engine. It's these problems that really need to be addressed, and kept in the back of ones mind. But we are here, and there are some smatr guys in the Forum. keep us up to date as your build progresses. Good Luck....
BadBowtie0727
Posted: 03/15/13 10:46 PM
Very true bob...just went thru all of that last wk...I didn't use cam button. I had to drill/tap block nipples for lifter hold down plate due to not using retro fit...now not idling correctly due to stock 305 computer and tbi...but did install chip and adjustable fuel regulated....ideas?
Posted: 03/15/13 11:35 PM
I answered some of those questions on your other post. See if that helps any. If not get back to us.
