62 327 DIFFERENCE BETWEEN 250 & 300 HP-What modern fuel to use? - Chevy Forums at Super Chevy Magazine Super Chevy
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
garygbnj garygbnj
I love my Chevy Chevette! | Posts: 1 | Joined: 10/12
Posted: 10/06/12
04:39 AM
Besides the double hump heads are there any other differences between the 2 engines?
They are both 10.5 to 1 compression.  What modern fuel will they run on?  Do the valve seats have to be redone for survivability?
The corvette 327 is 11:1- what modern fuel do they run on?
thanks
gary
pepsi1 pepsi1
Big Block power for the win | Posts: 899 | Joined: 03/11
Posted: 10/06/12
06:57 AM
It has a little more camshaft... Believe eit or not that is it...
pepsi1 pepsi1
Posted: 10/06/12
07:05 AM
garygbNJ welcome to Super Chevy.
Is there a reason you need to have the engine specs? If so I'll dig them up for you.
Does the NJ in your name garygbHJ mean New Jersey. If so there are a couple guys on the Super Chevy site from there...
pepsi1 pepsi1
Posted: 10/06/12
04:11 PM
"1962 Technical Specs for Chevrolet Engines"
HP  DISP  Comp/Ratio      Carb          R/Ratio  Cam/Type  Head/CC
250  327      10:50      Carter/AFB        1.5     Hyd      62.20cc
300  327      10:50      Carter/AFB        1.5     Hyd      62.20cc
300  327      10:50      Carter/AFB        1.5     Mech     62.20cc
340  327      11:25      Carter/AFB        1.5     Mech     62.20cc
pepsi1 pepsi1
Posted: 10/06/12
05:00 PM
"1964 Technical Specs for Chevrolet Engines"
HP      Disp     Deck     Valve Size     Cam Lift    Head Casting #'s
365     327      .014     1.725/1.505    .399/,399   876,520,842
375     327      .014     1.945/1.505    .399/.399   041,186,291,461,462,492
pepsi1 pepsi1
Posted: 10/06/12
05:21 PM
HP   Disp  Comp/Ratio    Carb         Manifold  Cam/Type       R/Ratio   Head/Vol
365  327   11:0       Carter/AFB      3844461    Hydraulic        1.5      58.68
375  327   11:0       Fuel Injected   3826810    Mechanical       1.5      58.68
300  327   10:5       Carter/AFB      3799349    Hydraulic        1.5      57:50
250  327   10:5       Carter/WCFB     3844457    Hydraulic        1.5      54.90
pepsi1 pepsi1
Posted: 10/07/12
12:42 AM
Just some FYI for CHP guys:
I finally found my Chevy and Ford specs. Depending on your application I can get you CarburetorNumbers intake manifold numbers etc. All I can say is no I don'thave the number.
redneckjoe69 redneckjoe69
Everything in my driveway’s a Chevy | Posts: 604 | Joined: 02/10
Posted: 10/07/12
04:34 PM
i would say yes, you need hardened exhaust seats for todays unleaded gas.   11.1 is about the max compression for todays gas, if you have aluminum heads.   cast iron,...10.1 max.
pepsi1 pepsi1
Posted: 10/07/12
07:50 PM
+1 Joe:
I would do both intake and exhaust valve seats. With the heavy valve spring loads it will really raise hell with the valve seats. Plus the heat of the combustion temps.
Did you see any of the Dega 500?..
Posted: 10/08/12
06:36 AM
yes, it was an awesome race i thought.    looks like only the top 3 are gonna have a shot at the title.
