Item Posts
Sort Order
wiper motor wiring
bluenel
Posted: 02/01/10 12:43 PM
I'm trying to put a wiper motor under the dash of my 64 el camino.The motor is from a 90-95 c1500.It has 5 wires white ( which I belive is the 12v) black (ground), purple, gray and orange. What are the other wires for? what kind of switch should I use? Would a simple toggle sw work? Do not what to change the steering col. thanks
Posted: 02/01/10 11:00 PM
here is the wiring diagram for the year of the truck you got the motor for..
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/08/f3/d2/large/0900c1528008f3d2.gif
i think that gm uses the same style of motors through out the line.. but finding a switch thats not on the turn signal stalk.. hmm...
got any friends at parts distributers??? see if they have any delco 15A91 catalogs or 15A99 catalogs laying around..
perhaps one of the aftermarket manufacturers parts catalogs.. napa online used to have a really searchable site.. they changed it..
perhaps this
http://www.colehersee.com/catalog_top/index.htm
perhaps this Product Family: Windshield Wiper Switches : 75600 Description: Microprocessor-Controlled Electronic Wiper Switch Specifications Type of Motor Both One or Two Motor Operation controls one motor For use with: Negative ground permanent magnet wiper motors Mounting Stem Thread 7/16" -28, .45" (11.43mm), hex nut and lockwasher included Terminations Packard 8-way female connector #2965977 Rating 12V DC Case diecast case 2-7/32" (56.35mm) square, 1-13/16" (46.04mm) long Knob black plastic with metal insert and set screw, white imprint Positions Off/Park - Intermittent Range - Low - High Lead and Connector Assembly 5.625" (142.87mm) long
here is the catalog pages.. for the wiper switches..
http://www.colehersee.com/pdf/master_cat/m_wiper.PDF
it will take me a while longer to find what the exact wire colors are for..
i am going to guess that orange is the power to turn on the motor from the switch..
white seems to be switch ignition power... that has to be on for the system to work.. it allows the motor to return to park when the orange wire is switched off..
i have needed to look this information up... so it really is not a huge problem.. i have a friend with a 78 seville.. with a 3.9 isuzu turbo diesel NPR motor and electromatic transmission.. his other mechanic never finished the job.. getting the wipers to work properly is on the list.. the turbo outlet to intake inlet tube is right in the way for the factory gm wiper motor.. something else is on there now.. and that install was not easy.. lots of cutting.. firewall, trans tunnel, cross member.. oil pan,
Administrator
Posted: 02/02/10 09:36 AM
I've got a '92 Silverado. They had a special electronic board that controlled the motor mounted on the firewall near the master cylinder. Did you also get this part from your donor truck?
bluenel
Posted: 02/02/10 09:46 AM
YES THANK YOU
