1967 327 ,the good and bad
ryanbaker454 ryanbaker454
V-6 Camaros rule! | Posts: 34 | Joined: 02/09
Posted: 05/16/09
03:14 PM
what is the good and bad for a 67 327,it has 80-86 heads on it and they are 64cc i beleive,has a solid cam with regular solid lifter and flat top pistons and a steel balanced crank.was told it is 10:1 comp but dont know for sure.has torker edelbrock intake.which carb should i run i have a 750 and 600 edelbrock.let me know what you think.
Pontiacman2 Pontiacman2
Posted: 05/16/09
03:37 PM
1967 was still the small journal I believe so that is the better 327.
What is the casting numbers on the heads.
With a flattop piston and a 64CC head you will have a 9.2-9.5:1CR. Cool  Cool
Posted: 05/16/09
03:39 PM
the block number is 3782870, head casting number 14014416, is this a good setup,what kind of horsepower am i produceing roughly.
Posted: 05/16/09
04:13 PM
what is the cam specs.
Posted: 05/16/09
04:20 PM
dont know,i know it will rev till you put a rod through the hood
Posted: 05/16/09
06:17 PM
Are the heads ported what other work was done to them.
chevelle83 chevelle83
Posted: 05/17/09
07:10 PM
I have a small journal 67 327 Is this a good block to build???? I also have the original heads too. They are the small valve truck heads 58CC
