Harmonic balancer crankshaft bolt
kosovoal2002 kosovoal2002
V-6 Camaros rule! | Posts: 68 | Joined: 06/08
Posted: 08/15/08
04:32 AM
I have seen a posting on this before. I have a 350 chevy motor with problems with the bolt the holds the harmonic balancer. It appears that the bolt threads on the crank may be gone. I understand that the crank is hardened, is there something that I can do to make sure the bolt is secure. I tried a longer bolt but that did not work.  thanks
55Guy 55Guy
Posted: 08/16/08
12:15 PM
You have to rethread the nose of the crank. You'll probably need to take it to a shop and let them do it, since a pretty heavy duty tap is gonna be needed.
Posted: 08/17/08
08:18 AM
Thanks. Are they going to use the same size tap or are they going to have to go to a size bigger? I have an industrial tap that is the same size of the bolt. It is a bottom tap that may be able to pick up what is left of the blind hole.
