Item Posts
Sort Order
350 chevy
joeyfast13
Posted: 07/13/08 04:41 PM
ok i have a 1982 chevy silverado it has a 350 chevy bored .30 over and a 390/480 cam i am running a stock gm alluminum intake from a 1980 corvette and a holley q-jet replacement...My ignition set up is accel oem replacement distributer and a accel supercoil...Flowtech Headers..And a turbo 350 trans with a lock up converter which is un hooked...So i am asking what should i set my timing at and what do i gap my plugs before i had the transmission with a lock up converter my truck would go alot faster more take off is this because i dont have my lock up converter hooked up and if so how do i hook it up
joeyfast13
Posted: 07/13/08 04:44 PM
Also i dont know if my 4 barrels are kickin in or not its vaccum and i dont got much cuz my cam
Administrator
Posted: 07/14/08 07:22 AM
Same ignition system for the truck and Corvette, so spark plug gap is the same.
As for the timing, start with factory timing, then fine tune from there.
joeyfast13
Posted: 07/14/08 09:57 AM
Ok i think i got it set 45 degrees advance since it is a mild cam but im not sure exactly what size cam all i know is they guy put 390/480 cam on the paper that i bought the truck from when i am at a dead stop then punch it it bogs down before it takes off same way if i have the gas half way then punch it it takes a minute also how can i chevk to see that my 4 barrels are kickin in.....where can i find rv cams at i have looked
Posted: 07/14/08 12:26 PM
Sounds like the accelerator pump isn't adjusted properly.
joeyfast13
Posted: 07/14/08 03:45 PM
ok i have read to set the pump arm WOT then use a feeler gauge to set it at .15 clearence could this mean i be to lean or to rich i am new to holleys pretty much learning....what does a lock up converter do? Thank You
Administrator
Posted: 07/17/08 07:20 AM
A lockup converter has no slippage when the trans is in its final gear. It locks the impellars in the converter so you have 1:1 going into the transmission. For a car ont he street, you want one.
fliplopoo
Posted: 12/02/12 07:01 PM
45 would be a bit much for even maxed out. 28-34 adv. at 3500 rpms. If your using a vacume advance it should be disconnected while setting timing and shoud have live vaccume at idle. Cams degreed in at 108 seem to pull more vacumme producing more low end torque. So when choosing a new cam reverse think the process to get all the specs in the right place. Is your carb a rebuilt quad by holley or a holley carb. Lots of differance but I am a Quad-jet fool. Hope your dist has a curve kit with weak spring set. HEI rotor is a weak point. Get a tan set its worth the extra bucks.RV cams are the worst,neither nor and sucks the gas. A 252H with 1.6 rockers is a great gas and low end torque cam. Bad plug wires can also cause a stumble. Check your valve springs and valve adjustment. You may have one a bit off. One weak spring are galded rocker on hydraulics can run you nuts. On solids too tight changes a lot of cam specs to the bad. Hope this helps. PS 110 lobe sep. allows a little more tune ability.
fliplopoo
Posted: 12/02/12 07:17 PM
76 Rocket 350 Olds had a more powerful coil and called for .085 spark gap but works on 45 OK but more cost efective and needs a tan cap and rotor to work corectly. Hotest thing going. Bench test before and after with nothing on the top and watch real fire power at work. Best be ready to go up on jetting to match and watch your horses climb.
fliplopoo
Posted: 12/02/12 07:28 PM
O lash at idle on holley carb pump. Make sure squirters are working properly. To big on CFMs or pumps and squirters can dround a engine and cause a stumble.
Posted: 12/02/12 11:36 PM
after FOUR years I hope he got it figured out already
Posted: 12/03/12 07:16 PM
I have a question: When you disconnected your Trans Clutch, was it hooked to a vacuum source? If you have a vacuum advance HEI unplug the vacuum line from the distributor. Plug the open end set your base timing. Set the base timing @ 10*-12*. Now hook the vacuum advance back up. Bring the RPM to 1800RPM and set the total advance to 28*-32*. The cam you have is really a torque,low RPM cam. Mainly used for towing, or an RV etc. Set your Spark Plug Gap at .032 to .035 NO More then that. That will help your stock HEI. The TH350 trans you have is a TH350-C. It shouldn't effect your bottom end any, or the way your truck takes off.
Posted: 12/04/12 03:41 AM
68scott385: after FOUR years I hope he got it figured out already
+1 Scott, lol.
gotta look at the original date guys.
Posted: 12/07/12 08:23 PM
Holey Chit Joe who pulled that dead one up?
